1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Coil Overs
Old Jun 7, 2006 | 02:07 PM
scatpackmopar's Avatar
scatpackmopar
Default Coil Overs
What are the pro's and cons of having coil overs? I want to avoid a stiff ride
Old Jun 8, 2006 | 08:06 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Coil Overs
Judging by the last statement...stay away from coilovers. Coilovers are shorter springs and therefore will have shorter travel and since it has to have a shorter travel, they are made to suspend X amount of weight with less coils = stiff. Springs are naturally longer, even lowering springs...stick with the springs, they will keep you closer to a stock ride.
Old Jun 9, 2006 | 12:36 AM
scatpackmopar
I don't mind a firm ride. Just as long as it doesn't turn into a harsh feeling ride. I was hoping to find out coil over is the best way to make my car turn better and keep the body roll to a minimum without sacraficing too much of my smooth ride.
Old Jun 9, 2006 | 12:44 AM
silvercoupe97
Uber Moderator
ORIGINAL: scatpackmopar
Yes, you can get both a comfortable ride and good cornering from a coilover package, but if you look around, they start at $800 and work their way up to, well...as much as you're willing to spend. Most of the "newer" Avenger owners don't have a wallet that deep though and my suggestions lean towards that end most of the time because of it.
Buying seperate shocks and then coilover springs don't tend to cost as much as "real" coilovers and then they are so generically stiff that most are kidney busters.
Buying seperate shocks and then lowering springs will offer you what you are looking for. For daily street driven cars, it's fine. For closed circuit cars, coilover packages are what you want....are you willing to pay to play is the question
Old Jun 23, 2006 | 09:24 PM
avengerdude27's Avatar
avengerdude27
as far as coilover go
if youre going to do it as silvercoupe said do it right
tien setups for the 95-99 eclipse work well dont do the electronic dampening control lots of cutting needed in the strut tower
then the correct camber kits...ingalls work well
then an alignment
Old Jun 24, 2006 | 10:19 AM
silvercoupe97
Uber Moderator
ORIGINAL: avengerdude27
then an alignment
So are you saying that the shock tower needs to be modified to accept the pillow ball mounts?
Old Jun 24, 2006 | 09:56 PM
avengerdude27
no the pillow ball works fin ...infact i reccommend it
the EDFC(Electronic Damping Force Controller) doesnt work without mods
Old Jun 24, 2006 | 10:05 PM
silvercoupe97
Uber Moderator
I didn't think the EDFC would fit without pillow ball mounts since the PBM lowers the strut all together.
Tein recommends them for use with the EDFC too.
Old Jun 24, 2006 | 10:13 PM
avengerdude27
yes you need the pillowball to use the edfc but you also need to do some cutting on a veng in order to use it
and the edfc and only be used with the flex or superstreet setups (with pb mounts)
Old Jun 25, 2006 | 08:10 AM
95_Avenger's Avatar
95_Avenger
i beg to differ on the 800 price range http://cgi.ebay.com/ebaymotors/SKUNK...01363040QQrdZ1
and shipping is free..
