1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
noise when turning
Old Jun 10, 2006 | 01:46 PM
redaveng99es's Avatar
redaveng99es
Default noise when turning
I hear a really light winding noise or somethign everytime I turn the steering wheel. Its nothing to do with the control arms and stuff. I checked fluid and its ok. Anything else I should check. Sounds like it could just be rubbing or something maybe.
Old Jun 10, 2006 | 11:34 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: noise when turning
Whining?....like pulley whine? or is it belt squeal? or is it more of a grinding? or screeching? are you going over bumps or any change in suspension configuration (I'm being generic)? at what speed(s)?
Check your power steering fluid and make sure that it's up to par, check your power steering belt and make sure it doesn't have a lot of play per manual. Check your lower balljoints, the backside of the brake disc, the brake pads....there's an "indicator" that only lightly sqeaks/squeals when it's starting to get rubbed down to the nub.
Old Jun 10, 2006 | 11:36 PM
silvercoupe97
Uber Moderator
During idle, turn your steering wheel in both directions, if it makes any "off" noises, then it's your power steering component. If it's good, then try and replicate the issue and post back with more detail bubba.
Old Aug 9, 2006 | 06:59 AM
avenger9689's Avatar
avenger9689
According to my Haynes Repair manual troubleshooting section, If you hear a clicking noise when turning, then its a worn or damaged outboard CV joing. Heres something else that might help. If there is noise that is most pronounced when turning, then its a Differential gear noise
Old Sep 25, 2006 | 04:06 PM
FoniksKyd's Avatar
FoniksKyd
My 96 avenger has a grinding noise when i turn the steernig wheel and even when i get in and out of the car. obviously this has to do with suspension. can anyone confirm that this could be a possible problem with the lower ball joints? i know that there was a recall for these in may of 01.
Old Sep 26, 2006 | 01:16 AM
PappiDread6's Avatar
PappiDread6
I can Fon Just had it done last August. Does it sound like two metal pipes rubbing when turning and does it go away at high speeds say around 40+MPH! Its the lower ball Joint! Also I noticed it went away when it was wet outside or after it rained.
Old Sep 27, 2006 | 12:13 PM
scatpackmopar's Avatar
scatpackmopar
I get a faint whining noise when I turn. It sounds like fluid going thru the lines in the rack and pinion. Wonder if a flush of fluids would help that? Is there power steering fluid designed to help keep things quiet? I do not have any leaks or play in my steering so I am no that concerned about it and only notice the noise once in awhile in the parking lot.
Old Sep 29, 2006 | 12:45 AM
bgm's Avatar
bgm
i get the same noise with my 97, also what is the turning radius on our car's? my wheel turns once each way before it stops, and it's just terrible, any ideas?
Old Sep 29, 2006 | 01:21 PM
PappiDread6
I Honesty Do Know (IHDK) but I know its bad! When making a simple "U" turn I always hafta swing the car like I'm driving a truck, I just got the steering done so I do try to force it anyways. If it was RWD I would just give it more gas. And she understeers like I have no ABS, coming off a main road I always put her into 2nd. The best way I can describe my turnig radius is when cuttin the wheel to either side I.E the left, the right tire has about and inch clearance from the fender.
