1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
The PCM
Old Aug 14, 2006 | 01:44 PM
aarojack's Avatar
aarojack
Default RE: The PCM
Problem Solved, the car runs and charges, I took it for a 3 mile run, stop at a gas station put air in the tires, road around the block a few times.
Atleased she is drivable now. thanks alot silver.
Now the only problems left are the ABS, and the heat/air and rear defroster,
The ABS I checked the fuse and it was indeed fine, maybe a relay?
Going to recheck them though, is there anything else I should look at besides fuses?
EDIT:
ALL FIXED, I checked the fuse box in the passenger compartment had a 10amp fuse blown, replaced it and now have Heat/Air, and the ABS light when out and I can hear it engaging.
Tested it on some dirt.
Will drive it in the next few days on short trips just in case.
Once again thanks silver for the aviced and look outs.
Old Aug 16, 2006 | 01:19 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: The PCM
No worries bro
Thanks for posting your resolve too, it will help future Avenger owners on the site, so thank you bro.
