1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
PLEASE HELP!!!
Old Aug 12, 2006 | 09:54 PM
vancitykillah's Avatar
vancitykillah
Default PLEASE HELP!!!
I have a 1995 Dodge avenger ES. The car had been running fine except for the fact that i had cracked the water pump. I changed the water pump only to now find that my car does not start. It cranks and if i give it gas its alright but as soon as I let the gas go the RPM drops to zero and the car dies. Because of this I have also changed the spark plugs, spark plug wires, distributor cap, distributor rotor. The timing on the car is perfect so I ruled that out. I think it might be my ignition coil??? any ideas???
