1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
How-to: Remote key fob programming
Old Jan 24, 2013 | 12:20 PM
  #31
Silvrspoon's Avatar
Silvrspoon
Does this work on a 2004 Durango
Here is a quick HowTo on programming your own keyless entry:
1) Turn ignition to OFF.
2) Locate the Data Link Connector, its a black 16 pin connecter that is under the driver's side dash, right where your right knee would be. You have to look up into the dash from below to see it.
3) Ground pin 1 of the Data Link Connector by taking a wire or paper clip and running it from pin 1 to pin 4. Pin 4 is ground so you can just short pin 1 to 4 and it will be grounded. Grounding pin 1 tells the system you are ready to reprogram it.
4) Close all of your doors.
5) Turn the key to ACC then back off. The power door locks will lock/unlock. This is the signal that the system is ready for reprogramming.
6) Push a button on your key fob, doesn't matter which button.
7) If you have 2 key fobs, then press a button on the 2nd fob within 1 minute of pressing a button on the 1st fob. Both must be programmed at the same time. If you only have 1 fob then press a button 2 more times to signal that you only have one.
8) The doors will lock/unlock to signal the codes were received.
9) Remove the jumper wire from the data connector.
Old Jan 24, 2013 | 02:59 PM
  #32
bad venge's Avatar
bad venge
Section Moderator
I Would doubt it there's been three other folks in this thread ask if it will work , I'd post in the Dakota specific area
Old Jan 28, 2013 | 09:18 PM
  #33
dimasp6's Avatar
dimasp6
I have a 97 avenger auto and it doesn't seem to have the keyless interface because the locks never cycle when I try and put it into program mode. I checked my vin and it doesnt seem to have the interface. is it possible to install the keyless interface receiver thing? I already have a key fob.
Posted from Dodgeforum.com App for Android
Old Jan 29, 2013 | 11:38 AM
  #34
bad venge's Avatar
bad venge
Section Moderator
Obvious questions do you have power locks ?
Have you checked voltage on the Port ?
Old Jan 29, 2013 | 12:05 PM
  #35
dimasp6's Avatar
dimasp6
my bad, have power locks. the driver door can be opened even when locked from the inside but this doesn't open the passenger door. both doors door have power locks. when locked, there is no flashing green or red light. how would I go about checking the voltage on the port? port 1 or 4?
Old Apr 23, 2013 | 09:56 AM
  #36
cookiect2003's Avatar
cookiect2003
Default Dealer Replacement
Called a dealer to see If I could get a replacement fob.... $130.00! Guy says, "You want me to order it?" I said NOOOOOOOoooooooo click.
Old Apr 24, 2013 | 06:10 PM
  #37
bad venge's Avatar
bad venge
Section Moderator
http://www.ebay.com/itm/OEM-MITSUBISHI-CHRSYLER-DODGE-KEYLESS-REMOTE-ENTRY-KEY-FOB-TRANSMITTER-GQ43VT6T-/151032764048?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998%7CModel%3AAvenger&hash=item232a411690&vxp=mtr
Old Jul 6, 2013 | 09:35 PM
  #38
jmike33's Avatar
jmike33
I have a 2003 Dodge Dakota and the recommend?ed pin out didn't make the doors lock and unlock. There is no pin in the number one pin. Should I cut wires and short them behind the DLC? Does anyone know if those are the correct pins to short out for this truck?
Old Jul 8, 2013 | 06:18 PM
  #39
bad venge's Avatar
bad venge
Section Moderator
I Would doubt it there's been four other folks in this thread ask if it will work , I'd post in the Dakota specific area
Old Sep 30, 2013 | 07:51 PM
  #40
simmonsfr's Avatar
simmonsfr
I bought a remote. When I ground pin 1 it locks/unlocks. I press a button and my remote flashes. I do this two more times and and there is no confirmation. Am I doing something wrong? Do you have to remove the key after you start the programming?
