1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help please!
Old Sep 13, 2006 | 12:38 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Help please!
ORIGINAL: tspretiree
You could try putting a 3.8 engine and trans from a mini van in it. That will give you 315hp and 245 lb ft of torque. Ive thought about doing it to my 2.5 2000 Avenger. I want to know if someone else has done it bebore I try it.
It's a pretty tall motor, remember, it's made for a taller engine bay. Some have only used the 3.8 plenum for a larger intake volume (still won't do much since the motor has to be accomodated too). Not to mention the weight that would put onto the car, it would be just as heavy as my car with the AWD drivetrain without the AWD part, lol. IMO, if you're going to add weight onto a car, make it RWD or AWD. Remember that the back of the car dips when a lot of power is applied, not the front.
There's no way that my wife's 3.8L V6 in her GC will fit in my car. Plus, it's still an automatic!
Old Sep 13, 2006 | 03:08 AM
tspretiree's Avatar
tspretiree
What about a 2.7 that will give an extra 50hp. 2.5 rated at 150hp.. 2.7 rated at 200hp
Old Sep 13, 2006 | 03:30 AM
silvercoupe97
Uber Moderator
That's what the 6g73 3.0L V6 will put down in our cars. It's almost a bolt on or a swap process too, no modification of anything, you run the same computer and you run the same tranny that's already in the Avenger. The 2.7 nor the 3.8 have not been used in the Avenger. The Diamante's 3.8 throttle body has though.
