1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Speed Sensor
Old Sep 7, 2006 | 01:18 PM
morrisonsa's Avatar
morrisonsa
Default Speed Sensor
Where can I find it on a 99 dodge avenger. Haynes manual was less then helpful.
Old Sep 7, 2006 | 03:02 PM
cass813's Avatar
cass813
Default RE: Speed Sensor
I have the clintons. It was hard to find too, but its under "wheel speed sensor" in my brake section. It looks like its tucked in the steering knuckle next to the tone wheel. It shows it behind the up at the top near that rubber boot. I was just in there though. I think my book description sucks because I dont remember it being there.
If you need instructions on how to get it off just post and I'll condence what my book says or I can probably take a pic of the page and post it.
Old Sep 7, 2006 | 03:43 PM
morrisonsa's Avatar
morrisonsa
That would be helpful. Which wheel though :P
Old Sep 7, 2006 | 04:10 PM
cass813's Avatar
cass813
hahaha it just says "remove the front wheels speed sensor's reqiring removal". what a &*# book. But I asked and its on the drivers side.
i apologize I was looking in the wrong section, the cirris/breeze section has the pictures and all that. Our section is even smaller so I missed it. This is terrible!!
taking it off (the whole wonderfully explained 8 steps in the book)
1. do all normal stuff(batt/jack)
2. remove the inner fender splash shield
3. remove the clips securing the speed sensor lead
4. remove the retaining screw and remove the speed sensor
To install
5. attatch the wheel speed sensor with the retaining screw
6. secure the speed with the clips
7. install fender splash shield
8. connect normal stuff and make sure abs works.
I don't have any pics either.
Somebody else needs to post who's got experience with this one. I thought I could help with my book but it sucks.
Old Sep 7, 2006 | 04:13 PM
morrisonsa's Avatar
morrisonsa
Helps enough, Ill go try that, I didnt take off the splash shield so maybe thats why I didnt see it.
Old Sep 7, 2006 | 05:01 PM
morrisonsa's Avatar
morrisonsa
Took everything off, and still just dont see it. This one is making me feel retarded.
Old Sep 7, 2006 | 05:56 PM
cass813's Avatar
cass813
my friend also said its on the transmission??
Old Sep 8, 2006 | 04:42 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You have it right Cass. It's one of those hard to spot, unless you know exactly what it is you're looking for parts. That wheel sensor is for the ABS though. If that's what you're looking for Morrisonsa, then both books are correct. You can also turn the steering wheel so that the tone wheel is a little more visible. If you can't find it, chances are, you don't have ABS. Besides the brake line, there should only be one more line going to the wheel hub...that's a good way to find the speed sensor.
Why, may I ask, are you looking for this part anyway?
BTW, it's the same with my 97 shop manual also. The pics are the same, so if both the manuals referrence the shop manual, they can't be that bad...right?
