Body Kit Options
It's not too bad. Remove the headlights, the 5 screws on the fascia (as soon as you open the hood, there is a black strip of metal screwed onto the rubber part of the bumper cover), remove the turn signals, I would suggest putting the front on jack stands and remove your wheels and that wheel well plastic guards because removing the 4 bolts (2 on each side) and reinstalling them while trying to get your new bumper fitted on while be a pita if you don't remove them the first time out, so make is easier on yourself and take the 2-3 extra minutes to jack it up or you will be there trying to put those bolts back on for 2-3 hours......trust me, I went through it with the stock fascia the first time, after that, I knew what had to be done and it takes me no longer than 15 minutes while chasing my 2.5 yr old son.
