1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Stuck in 2nd gear...
Old Oct 3, 2006 | 10:26 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Stuck in 2nd gear...
The relays should be on the firewall, last I remember them to be is to the right of the brake resevoir...on the firewall, right behind the battery.
Old Oct 3, 2006 | 09:10 PM
airman's Avatar
airman
silvercoupe...i saw 3 there that i could switch, and i moved each one to the right once, and it still had no effect.
update: it still sometimes goes into limpmode while i have overdrive turned off. *angst*
Old Oct 6, 2006 | 09:52 PM
airman's Avatar
airman
anyone? now with overdrive turned off it's no different than when i have it turned on. so what else can i try? i want my car back...
Old Oct 7, 2006 | 02:20 AM
silvercoupe97
Uber Moderator
Well, it could be a few things. The CPS, the distributor's cam shaft sensor, the PCM, the clutch pack, the torque converter, even the fluid. I'm probably forgetting something, but those are about the most common...so to speak.
Old Oct 8, 2006 | 01:27 AM
airman's Avatar
airman
i may take it to autozone and pull the codes off of it for myself and post them up here. fluid's not the problem, first thing i did actually. shop still says it needs a rebuild.
how would the torque converter cause this? out of those things you listed, what would be the hardest to change out?
let me restate the absolute current symptoms:
normal for about 2 minutes.
say, going down a hill, and accellerating to go back up. trans is in neutral.
rev it a couple of times, and snaps into second.
doesn't downshift at all. goes to neutral ON OCCASION for a few minutes when you let off the gas.
after about 5-8 minutes of driving though, permanent limp mode.
i don't want to shell out $1400 big ones but i will if i have to.
Old Nov 2, 2006 | 03:22 AM
apachie64's Avatar
apachie64
Hey did you ever find out the problem with your tranny stuck on 2nd gear?
Am having the same problem with my Avenger 95 2.0
It would nice if you can help me out with some infromation Joseph.
