1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
tuning parts
Old Sep 27, 2006 | 05:48 AM
2000silveravenger's Avatar
2000silveravenger
Default tuning parts
Does any one know of a good website 2.5l v6 avenger aftermarket parts. And i also need to know if there is a way to clean my headlight covers. I dont feel like paying 300 dollars for new headlights.
Old Sep 27, 2006 | 12:07 PM
scatpackmopar's Avatar
scatpackmopar
Default RE: tuning parts
You can find headlights for less than $300. I found my headlights on ebay for $150. New. Wet send the current ones and then polish them with a good compound and a buffer [not an orbital buffer, they are actually only supposed to be used for applying polish, not the actually polishing]
Old Sep 28, 2006 | 02:17 AM
cky00's Avatar
cky00
vheck out some of the how-tos at aseclub.net and they can tell you where to go for headlights and also how to get rid of the foggy headlights
Old Sep 28, 2006 | 02:39 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I've got a resource list in the Faq/sticky area of this forum. Everything from motor to body to lighting. Check it out bud.
Welcome to DF also
As for the headlights, as mentioned by Scat, you can find headlights for our cars for $150 now for the pair if you really want new ones or you can also wetsand them. No matter which one you do though, you will eventually have to wetsand them again or buy new ones again, so my vote is to wetsand them. The buildup is on the outside btw, not on the inside.
Old Sep 28, 2006 | 02:34 PM
PappiDread6's Avatar
PappiDread6
Yeah I was wondering bout that cuz I wanted to take off the cover but didnt know if it was air tight. I also wanted to know if using Vegetable oil works?
Old Sep 29, 2006 | 06:45 AM
silvercoupe97
Uber Moderator
It's semi air tight Pappi. There's a dump tube off to one side of the housing to release pressure build up from the heat of the bulbs or just build up from cold to hot. It is water tight though. The lens is also sealed and clipped on.
