1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
engine probs
Old Oct 4, 2006 | 08:19 PM
jp_greenville13's Avatar
jp_greenville13
Default engine probs
stuttering at 4000 rpms and really low idle. changed.....fuel pump, fuel filter, throttle positioning sensor, coolant temp sensor, spark plugs, wires, distributor cap, others? any ideas. this thing is running like crap and MY car isnt supposed to run like crap.
Old Oct 4, 2006 | 10:19 PM
PappiDread6's Avatar
PappiDread6
Default RE: engine probs
Only thing I could think of is that you have transmission probs or sumthing wrong with your heads.
Old Oct 4, 2006 | 10:32 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Check your spark plugs, clean your throttle body, make sure your air filter isn't clogged. Change your spark plug wires and plugs if they are worn. That's about all I can think of that might be causing stuttering at high RPMs and the rough idle. How is it out of those ranges though?
Old Oct 5, 2006 | 01:40 AM
jp_greenville13
it runs ok between 1 and 4 but it doesnt have the throttle response it used to. ive been thru plugs and wires. as stated above all ignition stuff has been changed.
Old Oct 5, 2006 | 01:46 AM
silvercoupe97
Uber Moderator
I would try cleaning the intake tract then. Use something like MCCC or Seafoam to clean the intake and chambers, put some in the gas tank to clean the injectors. It's not expensive, just time consuming. Sounds like something is clogged or partially clogged.
Old Oct 5, 2006 | 08:51 PM
jp_greenville13
i think that and also something electrical. i want a higher velocity intake too. got any suggestions that will save me some $$$???
Old Oct 19, 2006 | 10:44 PM
jp_greenville13
FIXED
the culprit: EGR valve stuck wide open.......duh
Old Oct 19, 2006 | 11:30 PM
silvercoupe97
Uber Moderator
ORIGINAL: jp_greenville13
FIXED
I see, thus causing pressure issues.
That's another reason why I'm glad Oahu doesn't have emission laws and why I removed my EGR system.
Old Oct 21, 2006 | 12:25 AM
jp_greenville13
mines pluggedno more vac problem. i also gutted my converter(catalytic)
