1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
front tweeters
Old Oct 21, 2006 | 01:34 AM
95_Avenger's Avatar
95_Avenger
Default front tweeters
ok so idk about the newer avengers but my 95 has two tweeters in the front but i cant figure out where the wires are to hook them up?? where are they ran to they aint by the the other ones??
Old Oct 21, 2006 | 05:50 AM
slhomer's Avatar
slhomer
Default RE: front tweeters
If your 95 came with the Infinity sound systen then they are routed to the trunk beyween your rear speakers.
My question is how do I remove the covers to replace them
Old Oct 21, 2006 | 06:07 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
To remove the covers, you simply take a flathead and pop them out. The tweeters are mounted on the covers, well, really it's the other way around. If you don't have the infinity system, the wiring, or plug, should still be there, since they are all prewired from the factory. The wires are ran to the back where the stock amp is found....under the rear deck lid and in between the two 6x9s.
Old Oct 21, 2006 | 01:04 PM
robertwyoung's Avatar
robertwyoung
I used a tiny allen wrench to lift mine ... small enough to go in the grill.
I also replaced mine with Infinity Kappa Perfect tweets, but mine weren't stock anyway.
Old Oct 23, 2006 | 01:49 AM
AvengerNewb's Avatar
AvengerNewb
Then what are the green wires that remain used for? My stereo was stolen, and I am trying to save a buck and install a new one. I am lost on what wires go to , I do have the front and rear speakers accounted for, and the accessory power, red striped, but as far as a Hotwire, all I have is blue, and no multimeter to check. Is the blue wire on my 97 the Hot constant for memory?
Old Oct 24, 2006 | 08:53 PM
slhomer's Avatar
slhomer
Blue is your main power that works with the ignition, I am going to run a new lead for my memory. one green is for illumination Ill double check them to night for you
I still have the head in my garage and it has the schematic on it.
I spent 6 hours last night ripping out my old infinity and installed my alpine with an electric cross-over and 3 amps it sounds much better now
Old Oct 25, 2006 | 04:09 AM
slhomer's Avatar
slhomer
the red wire is for memory I didn't have a good connection
