1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
alternator wiring harness
Old Nov 25, 2006 | 12:35 AM
hckyplayer8's Avatar
hckyplayer8
Default alternator wiring harness
unfourtanetly yes i am still having eletrical issues.....the green wire tore outv my alternators wiring harness n i tried 2 fix it by just taking the spade n crimping it to other wire (not solid wire either) n then using the shrinking butt end connectors 2 try to fiz it but its not working.....before i go and replace the whole harness wut should i expect to encounter.....thanks
Old Nov 25, 2006 | 09:29 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: alternator wiring harness
You will most likely have to pull out the wiring out of the split loom. I don't see there being an issue other than putting all back to mimic the stock routing, lol. Just make sure to remove the battery from the equation, not that you won't but I just want to make sure I mentioned it, lol.
Old Nov 25, 2006 | 12:15 PM
hckyplayer8
yea i thought about that 2.....ok thanks for the help
