1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
painting trim- silicone problems
Old Nov 25, 2006 | 03:14 PM
jp_greenville13's Avatar
jp_greenville13
Default painting trim- silicone problems
how do i prep a silicone contaminated surface?
Old Nov 27, 2006 | 01:48 AM
ProjectVenge's Avatar
ProjectVenge
Default RE: painting trim- silicone problems
PPG made some stuff called Dt330. Its what i had to use when i did touch up work because of all the silicone dealers spray on car.Thinner should work just as well just have to be alittle more careful cause you can damage paint or clear coat if your touching up around existing paint.Im pretty sure you can find some equivalent at your local parts shop.
Old Nov 29, 2006 | 10:16 PM
99_avenger's Avatar
99_avenger
ha ha look what have
