1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
HELP
Old Jan 16, 2007 | 01:49 AM
element000101's Avatar
element000101
Default HELP
I Sealed up the hole from my old spolier but it is still leaking, it looks like its coming from the wheel well, i pulled back the carpet and its all wet, and ideas where it could be leaking from?
_____________________________
Old Jan 16, 2007 | 11:08 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: HELP
Check and make sure the lid is seated squarely and that the water drain passages aren't clogged or have holes.
Old Jan 17, 2007 | 11:40 AM
element000101
Default RE: HELP
where are they drain holes, and it seems like the water is coming from the wheel well
Old Jan 18, 2007 | 06:02 AM
silvercoupe97
Uber Moderator
Default RE: HELP
You could have a leaking window seal. How does the seal that goes around the trunk opening look? Check it for rips/cuts. If it is coming in from the wheel well, you could flash a light by the wheels and look inside the trunk for the light. Just a thought.
Old Jan 18, 2007 | 11:28 AM
element000101
Default RE: HELP
yeah my friend was saying buy that spray "Truck liner" stuff and spray the inside and out side of the wheel well, will that work
Old Jan 18, 2007 | 11:31 AM
silvercoupe97
Uber Moderator
Default RE: HELP
I don't know, I've never tried that before, lol. I'd try and find the leak and just bondo it...after you clean it up so that it doesn't rust.
Old Jan 18, 2007 | 12:50 PM
04blksrt's Avatar
04blksrt
Default RE: HELP
hey silvercoupe...for some reason i cant PM you but i had a couple of ?'s about your car.....maybe someone else on this forum can shed the light im lookin for... #1- what model of avenger came AWD? #2- did the car come turbo'd and AWD? #3- i havent checked your list of mods, but what does it run on the track (that is if you have ran it on a track) and what are some kills you've got knotched on the ol' shifter...what im getting around to is how fast is the thing. are you runnin all over us SRT's, and EVO's, STI's? regaurdless.....you've got a beautiful car, and i deff. like the fact its AWD & TTTTTURBO"D. nice ride!
Old Jan 18, 2007 | 01:04 PM
silvercoupe97
Uber Moderator
Default RE: HELP
Oh crap, I forgot to turn my PM's back on. There was this spamming thing going on during the holidays, so I turned them off, sorry
To your questions. The Avenger/Sebring never came with AWD or turbo...sadly. I had an Eclipse GSX swapped into my Avenger with all the goodies a 4g63 motor needs to perform and last for awhile, like a 6 bolt block, Centerforce clutch, 4 spider center diff, etc.
Shortly after I arrived here on Oahu, they closed the track, so I haven't had a chance to run her on one yet and I don't street race so, no, no notches, lol. I have played around with my buddy in his EVO 9 with light performance mods though. At the time, I still had a side mount intercooler, an FPBig28 (close to performance as a Big16G) boosting 14-15psi and was running rich and he only slowly pulled away before we quit. Now, I have a front mount intercooler, still have the FPBig28 but boosting at 21psi this time, and I'm pretty stoich all the way through the RPMs and I pull pretty hard. I haven't "played" with my buddy lately though, he's also upgraded a few things since then, lol. I've got friends with all the cars that you mentioned, but we only "play" around by passing each other on cruises, lol.
I can tell you that my car is no slouch....anymore, lol. Click my sig and you'll see what was done and what I have for mods
Thanks for the nice comments too and I'll turn my PMs back on, since we don't have that pesky spammers anymore.
