1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Battery Corrosion Screwed me over
Old Jan 17, 2007 | 12:52 AM
2000BlackVengerES's Avatar
2000BlackVengerES
Default Battery Corrosion Screwed me over
When owned by a previous owner my 2000 Dodge Avenger ES experienced a batter explosion. My mechanic found out that underneath everything corrotion is taking over. Is there any way to get rid of corrortion and maybe replace some damaged spots w/o being too expensive?
Help would be great
Thanx
Old Jan 18, 2007 | 09:28 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Battery Corrosion Screwed me over
You could find the corroded area and solder some clean strips of wire. If you can see where the corrosion is and is readily accessible, then you should be able to do it. Shops usually charge at least $60/hr (around that price).
Old Jan 22, 2007 | 07:01 PM
2000BlackVengerES
Thanx. SC. Also i was looking for some HOW To info on changing a Washer Fluid pump. I'm sure that's what's wrong, although it could be a fuse? Any idea where the fuse is located?
Thanx again, oh and by the way i got my limp mode tranny problem taken care of.
Old Jan 24, 2007 | 08:37 AM
silvercoupe97
Uber Moderator
Limp mode is gone!! Woot!
The pump is fairly easy to swap out, it's a matter of popping out the old one and popping in the new one, lol. Getting the resevoir out of that cramped area is something else, lol. I don't remember there being a fuse for the washer, so I will have to say to check all the fuses under the dash and in the engine bay...sorry that wasn't very helpful [>:]
Old Jan 25, 2007 | 09:02 PM
2000BlackVengerES
No, that was great. That's all i really needed. Thanx man.
Keep me posted with some stuff, if you're not too busy. I'd really like to learn a lot on this website.
Thanx again SC
I'll talk to ya later
