1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Door Handle Repair
Old Jan 20, 2007 | 07:29 PM
Trayton's Avatar
Trayton
Default Door Handle Repair
I just recently started cutting into my door handle to reinforce it with that kit in the sticky topics because one of my handles broke.
Anyone else having a really hard time actually cutting into the plastic and figuring out how to get it wide enough for the pieces without screwin it up severely?
I ended up havin to saw thru it multiple times (on the broken pieces) and used a dremel tool to shave down the insides of the pieces to get it to fit.
I gotta know if theres a better way to do it when i start my drivers side door handle... [>:]
Old Jan 21, 2007 | 03:31 AM
PappiDread6's Avatar
PappiDread6
Default RE: Door Handle Repair
YO! Hold up cut what?!! All u had to fdo was repve those outer screws around the door panel, the one inside the door grab under that plastic piece and the one behind the actual handle itself. After that that plastic outer triming around the door needs to be slide towards the front of the car and the gentle pull off the panel itself cuz the window switches are connected to a wire which is connect 2 the door. Then you could either unscrew or unplug the switch, then there are 3 screws on the handle and 2 lil thin poles that are behind it. I did't hafta cut anything at all. Wut u talkin bout?
Old Jan 21, 2007 | 04:17 AM
blackvenge34's Avatar
blackvenge34
yea i just removed the panel and the plastic then the handle came off with 2 bolts then i put the new one in peice of cake just a little tricky cuz you cant really get your hand in there to well its a tight sqeeze unless you have small hands or you know a diff way.
Old Jan 22, 2007 | 03:55 AM
Trayton's Avatar
Trayton
Yo pappidread, listen to what im sayin. REINFORCE IT WITH THAT KIT.
Im talkin bout that kit you buy online that has the two metal pieces to reinforce your doorhandles with dude.
im not stupid, i know how to take the handle out of the door itself.[>:]
Old Jan 22, 2007 | 12:38 PM
PappiDread6
Naw I know you aint stupid. I thought with the reinforcement kit all you had to do was place those piece behind the doorhandle. I got it now tho u threw me way off with the cuttin and havin small hands.
Old Jan 22, 2007 | 09:20 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I believe he was talking about this kit and install Pappi.
http://www.rcaz.com/rcaz/sub%20index...efix/index.htm
Old Jan 23, 2007 | 12:05 AM
PappiDread6
Uh Silver he put that up in his first post already. I was just wondering what he was cutting?
Old Jan 24, 2007 | 12:48 AM
Trayton's Avatar
Trayton
you have to literally slice down the length of the long pieces adjacent to the handle so u can slide those metal pieces in.
Old Jan 24, 2007 | 08:27 AM
silvercoupe97
Uber Moderator
ORIGINAL: PappiDread6
I saw that too . If you scroll down though, you can see what he's talking about and what he had to cut/saw.
Old Jan 25, 2007 | 10:45 AM
Trayton's Avatar
Trayton
So im guessing nobody else has used the kit yet... [>:]
