1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
power steering
Old Jan 26, 2007 | 07:06 PM
joecool's Avatar
joecool
Default power steering
My 99 2.5L avenger is giving a code for bad power steering pressure switch. So I'm trying to replace it and was wondering if anyone has done this before? The switch/sensor is blocked by the bracket holding the power steering pump in place. I figured that I'll have to remove the pump from the backet to change it. Is this right and does anyone have any suggestions for removing the pump like does the pulley have to come off to get to the bolts?
Old Jan 26, 2007 | 10:09 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: power steering
Are you losing fluid pressure or fluid? Is the PS fluid leaking past the PS resevoir cap? Or are you certain that it is the actual pressure switch that is throwing the code?
