1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
looking at turbo
Old Jan 27, 2007 | 02:58 PM
blackvenge34's Avatar
blackvenge34
Default looking at turbo
ok i found a couple of turbos on ebay just want an opion opinion
Ebay kit 1
or this one
Ebay kit 2
and is there anything i would have to change internaly if i was only running 7-8 psi and do i have to change my trans or nething i dont know that much about turbos n i can use all the help i can get
*edited for long link...silvercoupe97*
Old Jan 29, 2007 | 01:08 AM
blackvenge34
Default RE: looking at turbo
or this one
Ebay kit 3
Old Jan 29, 2007 | 08:37 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I don't trust ebay turbos, unless, there's a name behind it and they ususally don't come in "kits". A turbo isn't something you want to go cheap.
There's really only a few "kits" that I would recommend and those are the Star kits, Greddy, HKS, and Hahn kits.
Eclipse/Avenger Star turbo kit install..
Avenger/Eclipse Hahn turbo kit
Old Jan 29, 2007 | 02:07 PM
blackvenge34
ok and do i have to change any internals n wat bout the trans
Old Jan 30, 2007 | 03:06 AM
silvercoupe97
Uber Moderator
ORIGINAL: blackvenge34
Not if you keep the boost down and below at least 10psi. If you've got an automatic, then I would suggest getting a higher stall torque converter, LSD, and shift kit.
If you plan on going higher than 10psi, get the motor rebuilt with forged internals and lower the compression.
One thing to keep in mind at all times is that these motors, I4/V6 are getting old. Those internals are probably tired. Before boosting an old motor, make sure that it's running strong first with no leaks because forced induction will create more pressure and make small leaks even bigger and if it's not running strong, it will weaken it even more.
Old Jan 30, 2007 | 01:24 PM
blackvenge34
ok thanks i have a 5 speed would i have to get a turbo trans or nething or is mine ok or change the clutch?
