1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
belts slipping
Old Feb 2, 2007 | 08:39 AM
bigalnash's Avatar
bigalnash
Default belts slipping
ok sometimes not always when i drive my car it whitsles. the closest thing i can think of is the sound of a tea keddle going off and a whitsle mixed together lol... Im pretty sure its the belt slipping but im not sure... any advice? or an idea how much that would be to fix... i just bought this damn thing..
Old Feb 2, 2007 | 09:21 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: belts slipping
The best suggestion anyone can give you is....buy a Haynes/Chiltons manual for it. It's the best $17-$25 you can invest in.
As for you issue, if it sounds like a belt, chances are it is. There's not a lot that will or can make a squealing noise but the belts or a pulley or more. Make sure your belts are tight, make sure your belts aren't about to snap in half and make sure your pulleys are straight and not lop sided. Don't do any temp fixes if the belt needs to be replaced.
