1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 dodge avenger trans\tcm problems
Old Feb 8, 2007 | 12:01 AM
powerwagon1969's Avatar
powerwagon1969
Default 95 dodge avenger trans\tcm problems
95 avenger want shift gears all the time. I saw another posting about the 97 model. this car has 4 relays on the drivers fire wall instead of 3 that were bad on the 97,could this be the same problem but just all 4?
Old Feb 9, 2007 | 10:40 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: 95 dodge avenger trans\tcm problems
I would start at the obvious things first, like...your relays and fluid. The TCM normally doesn't "act up", it's usually the other electrical or mechanical parts first.
Check your fluid for level, color, odor (don't taste it though..), and for any metal particals. The fluid should be pinkish and shouldn't have a "burning" or "burnt" smell to it. Although, it won't smell pleasant to begin with, lol. The fluid is more commonly the issue though. The A604 tranny should have MOPAR ATF+3 running through it, anything else is a 50/50 gamble on if it works longer than a year, and in turn, shortening the tranny's life even more.
Oh and welcome powerwagon1969
Old Feb 17, 2007 | 12:42 AM
silvercoupe97
Uber Moderator
Anything new Powerwagon1969?
Another thing...kind of late, but...
The CPS can cause your car to crank but not start.
