1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Speaker rewire project
Old Feb 9, 2007 | 02:14 PM
jchan's Avatar
jchan
Default Speaker rewire project
I would like to run new wiring to all my speakers. What would be the best way to go about it? Is it better to try and follow the factory speaker wires or is there an easier method?
Old Feb 9, 2007 | 10:14 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Speaker rewire project
The easiest way that I found was to just run the wires on one side of the car so make sure you have enough wire to get to where you need it to go. I snaked mine around the dash so that it was hidden. The reason I say to wire it on one side of the car is because, you don't want the RCA wires mixed in with any of the other wires. It's just a general rule of thumb to not mix up the power and signal wires. Anyway, keep the RCA wires on one side and run the speaker, power (battery), and remote wire on the other side.
