1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Windows
Old Feb 23, 2007 | 04:08 PM
2000BlackVengerES's Avatar
2000BlackVengerES
Default Windows
I'm sure there was a post just recently sometime on the tightening of windows. Do you happen to still have that or can you tell me how to remove the door side to tighten the window down some. It rattles when you close the door and it's open some. Thanx
Old Feb 25, 2007 | 11:52 PM
Hiper10000's Avatar
Hiper10000
Default RE: Windows
I got the loose windows too. Didnt want the fingerprints on the black paint so i just pushed on the windows to close the door. When i read a post that said not to close the doors by pushing on the windows it was too late. I need to know too.
Old Feb 26, 2007 | 12:05 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Windows
There is a thread on it actually. It started off with window door seals and ended up with being a rattling window fix, lol. Here you guys go.
https://dodgeforum.com/m_652387/tm.htm
Old Feb 27, 2007 | 02:46 PM
2000BlackVengerES
Default RE: Windows
Thanx man
Old Feb 27, 2007 | 02:50 PM
2000BlackVengerES
Default RE: Windows
Hey what's the trick to getting the door panels off?
Thanx Silver
Old Feb 27, 2007 | 09:07 PM
silvercoupe97
Uber Moderator
Default RE: Windows
I don't have a trick really. Are you asking about how to remove the door panels? If so, here's a link to that..
http://www.redefinedrides.com/panel.html
If you mean that it gets caught on the trim at the upper part of the door panel, then nope, no trick, lol. I just pull it towards me so that the trim stays on the door. If you mean initially popping the door off, I always find the gap at the bottom of the panel and pry the panel and door apart with my finger (I used to pry with a flathead), after that initial prying, the rest is cake.
Old Feb 27, 2007 | 09:08 PM
jp_greenville13's Avatar
jp_greenville13
Default RE: Windows
door panels come off by unscrewing the four corner screws. unscrewing inside door handel cover and unscrewing screw hidden in door pull. other than that its just clips.nice even pull pressure and it should come out.
Old Feb 28, 2007 | 04:06 PM
2000BlackVengerES
Default RE: Windows
Thanx guys.
