1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
swap heads sohc dohc SILVERCOUPE97 "help"
Old Mar 10, 2007 | 02:41 AM
jermainebarker's Avatar
jermainebarker
Default swap heads sohc dohc SILVERCOUPE97 "help"
. But what want to know is if the sohc neon block is the same an the dohc in the venge? cause the dohc is hard to find junked and i rather justtake a few hours and swap blocks and get it running than to tare it down and rebuild just yet...Are the blocks the same? is it that easy to just swap blocks and everything match and bolt right up and be running in a few hours? i do want the low comp for my turbo app for a start..[:-][X(][>:]
Old Mar 10, 2007 | 09:02 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: swap heads sohc dohc SILVERCOUPE97 "help"
That is a good question, but one that can probably be answered by Avengerdude27. Here's his info..
https://dodgeforum.com/m_719917/tm.htm
If he can't answer your question for you, I'll see what I can do for you.
Also, the DOHC can be found in the N/A 95-99 Eclipse and the N/A 95-98 Talon It's the very same motor in our's and theirs.
Old Mar 10, 2007 | 09:23 AM
silvercoupe97
Uber Moderator
I was curious so I thought to search it and came up with a simple "no". The intake and exhaust is reversed compared to the 420a in the Avenger/Sebring/Eclipse/Talon.
Old Mar 19, 2007 | 05:38 PM
benjohnson's Avatar
benjohnson
Would'nt that be just a matter of swappingthehead? I'am new to this and just poking around for a little information myself.
Old Mar 20, 2007 | 11:42 PM
MoPaul's Avatar
MoPaul
they have been swapping the 2.4 bottom end into the Avengers. i think those may be the ones from the pt, though.
