1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Windowwashers Thing??
Old Mar 13, 2007 | 03:38 AM
PappiDread6's Avatar
PappiDread6
Default Windowwashers Thing??
Yo my windowashersquirt jet on my passenger side just clogged up. i was wondering if I should just use a saftey pin and stick it down there or there is sum way I can pop it off to clean it out. Hit a pimp up withany ideas that u have aight.
Old Mar 13, 2007 | 11:57 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Windowwashers Thing??
You should be able to remove that one and blow into it from the output side. If you do use a pin, use one that is smaller than the hole or you will have either a water hose squirter or a low pressure squirter, lol.
Old Mar 13, 2007 | 12:17 PM
PappiDread6
Yo Preciate the quick response. So how do you remove it with a flat head? Cuz its killing me having it the left side not working and the rightside squirting over the window.
Old Mar 13, 2007 | 12:25 PM
silvercoupe97
Uber Moderator
Lol, the right side is doing that because of the left side not working. Once you open up the left side, your right side will work normal again.
Lift your hood and pull the hose to the driver's side to see if IT isn't clogged. If you have an air tank and an air hose, you could blow the output side with air to blow out whatever is clogging the line. If not, you may have to use a really thin pin and blow out the debris...after you remove the nozzle that is, lol.
Oh yeah, at least the driver's window behind you has clean windows, lol. I can just picture that, lol.
Old Mar 13, 2007 | 12:34 PM
PappiDread6
ORIGINAL: silvercoupe97
LMAO! You mad stupid man!
Old Mar 13, 2007 | 01:09 PM
PappiDread6
I fixed the clogged but broke the "Y" connector.It was old and broke inside the tubethats y when i disconnected it, it broke so easily.Off to the junk yard again. Lets passengerside window motor, driverside seat handle, and window jet "Y" connector.
Old Mar 13, 2007 | 11:09 PM
silvercoupe97
Uber Moderator
Lol,
You can get those "Y" connectors at autozone also, $2 I think?
