1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Erratic idle fixed!
Old Mar 28, 2007 | 12:19 AM
marko69's Avatar
marko69
Default Erratic idle fixed!
Thought I'd share.
Replaced spark plug wires.....all better now.
'97, they probably had never been replaced.
$28.00
Old Mar 28, 2007 | 12:35 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Erratic idle fixed!
You gotta love the simple things
Thanks for the issue and fix.
Old Mar 28, 2007 | 12:49 AM
blackvenge34's Avatar
blackvenge34
wish mine was that easy im still trying to figure it out silver any way to find a where a vacum leack is coming from
Old Mar 28, 2007 | 01:11 AM
silvercoupe97
Uber Moderator
Well, you can plug the intake and get a handheld vacuum or pressurize the intake like you would with a boosted car. There's only a few places for vacuum leaks though. You could just replace the old lines with new ones. They are probably cracked and hard as rocks by now, lol.
You can also backtrack to what you did to the motor last.
Old Mar 28, 2007 | 02:32 AM
blackvenge34
how do u plug a vacume and a house vacume also how many lines are there and where are they located because it seems like that would be the best thing to do. its been idleing like that for a while after the intake manifold was replace it was fine but then after a while it started to act funny again if i replace the vacumm lines and it still does that what could be the reason?
Old Mar 28, 2007 | 03:11 AM
silvercoupe97
Uber Moderator
Lol, sorry, I meant a handheld vacuum test, like this one.
Which manifold? There's two, the upper (the one the normally referred to as the intake) and then the lower (sight unseen). Both have gaskets that can be seated improperly. Who did the work? A shop or you? If you did it, did you clean the area where the gasket sits? The throttle body has a shaft and seals that can go bad too (the seals), not to mention the BISS (4g63) or Base Idle Set Screw o-ring (if you have one).
You have to backtrack and think of the gaskets that may have been removed.
Old Mar 28, 2007 | 06:35 PM
blackvenge34
where can i get the pump and how much also a shop did the work and im guessing it was the top manifold and i can really take apart anything right now because im at school and no tools ironicly im at a school with an automotive program but dont have the classes yet lol so im thinkin of just starting with the vacumm lines
