Gen 1 hidden rust spot!
Ny gen 1's are in pretty good shape rust wise but doing a brake job right now and decided to pressure wash and repaint the inner fender wells while it is down. Found a spot where the weld was not tight and rust starting. Its high up in the well above the metal screw on metal panel thats under the mud flaps. You wont see it unless the truck is on a lift or stands and your scrubbing to repaint.
