Bad way to change oil?
Old Jul 8, 2012 | 12:37 PM
andy2510's Avatar
andy2510
Default Bad way to change oil?
For the last 9 years I've been changing oil in my 96 Dakota by unscrewing the oil filter & starting the engine to pump out the oil. It only takes a few seconds for it to pump the oil out. I have been doing this because the oil plug threads got stripped out & it is stuck in the pan. The truck has 185,000 miles on it now. I never expected it to last this long doing it this way. Ive had this truck for 13 years and drive it daily. I also change oil in it every 2000-3000 miles.
Old Jul 9, 2012 | 01:37 AM
WRXCarl's Avatar
WRXCarl
Hey welcome to the forum! I just noticed your from Cystal MN! I live right over in Brooklyn Center. See you on the roads!
Back on Topic
Considered getting a new pan?
Old Jul 9, 2012 | 11:58 PM
93MissDakota's Avatar
93MissDakota
yea i wouldnt do that. just get a new oil pan, or used at least. ive worked at an oil change shop for about 4 years and ive never heard of anyone doing that. just fix your drain plug issue somehow
Old Jul 13, 2012 | 04:00 PM
Rain's Avatar
Rain
Interesting. Sounds like a messy way and you risk running the engine dry.
You can buy a fluid extractor and suck it out from the dip stick. But ideally fixing a stripped drain plug is not too hard.
Use large vise grips and grip the stripped drain plug as tight as you can and turn it.
You will need to buy new drain plug / washer and retap the drain plug hole if it is crossed threaded.
