What's your gas mileage?
Old Sep 23, 2014 | 06:45 PM
  #41
onemore94dak's Avatar
onemore94dak
Originally Posted by OMGnanerpus
Will definitely check that out! Thanks
You have to remove the air conditioner and bracket to get to the thermostat. Its a bit o work.
While in there you might as well replace the thermostat, & the bypass hose (Vaseline is your friend), and maybe the top rad cooling hose. You will want to once you see how much taking apart you have to do to get at them.
The two sensors in there cost less than $20 each. There is also an intake air temp sensor on the passenger side of the intake just above the thermostat which I changed. I forget what it cost but it was pretty cheap.
Old Sep 26, 2014 | 01:05 PM
  #42
onemore94dak
I forgot to mention that yo do not have to drain the AC. You can remove the brackets and lay it over to the side the hoses are long and flexible enough.
Old Nov 10, 2014 | 07:00 PM
  #43
poormans sunshine's Avatar
poormans sunshine
From: oregon but am currently in the toilet bowl of America the golf coast of Mississippi
My 91 2wd 8 ft bed 3.9 3.55 gear set automatic with A/C driving from oregon to the Mississippi golf coast got 27 mpgs at a steedy 65 mph got 19going through the mountain passes in Arizona and neveda and new Mexico. Its almost worn out now it just clicked 93, 000 miles on the odometer
Old Nov 11, 2014 | 12:03 AM
  #44
RalphP's Avatar
RalphP
Hmm ..
Wonder what mine is at 283,000+ miles on ITS odometer ...
RwP
Old Nov 11, 2014 | 02:35 PM
  #45
poormans sunshine
Well seasoned lol
Old Apr 23, 2015 | 09:26 PM
  #46
mark miller's Avatar
mark miller
1989 untouched, on highway@20 mpg
Old Apr 23, 2015 | 09:51 PM
  #47
mark miller
Get 20 with my old 89 4x4.
Old Jun 13, 2015 | 04:28 PM
  #48
db4x4dakota95's Avatar
db4x4dakota95
Question 95 v-8 Dakota 4x4 gas mileage
Bought truck new in 5-'95. 14 mpg from then up until now, hi way or city. Can't improve it. Why?
Old Dec 12, 2015 | 03:54 PM
  #49
OMGnanerpus's Avatar
OMGnanerpus
Got a new truck, guess i should post my new mileage? lol
I get 9mpg around town with a 5.9l Magnum. Ram 2500 axles, so it has about 12" of lift, and it's on some aggressive 33" mud tires. The axle tags say it has 4.55 gears, but i'm not positive. Have yet to jack up the rear end or pull of the cover and check
Old Oct 2, 2016 | 01:56 PM
  #50
Ralph4199's Avatar
Ralph4199
95 2.5L 5spd ave 25-28 with most driving @ 40-60mph
