engine swap...help
Old Jul 21, 2013 | 12:47 AM
rushings4's Avatar
rushings4
Question engine swap...help
Not sure how this posting threads works but.... i need to know if i can swap 1999 durango motor into 1995 dakota.
Old Jul 21, 2013 | 10:59 AM
Brian in Tucson's Avatar
Brian in Tucson
Sorry to sound like a grumpy old fart, but please elaborate.
Are you putting a V8 into a V8 dakota, a V8 into an I4 Dakota? Makes a difference.
Short answer is, tho, yes you can. A 99 V8 will work in a 95 Dakota, you just need to take all the 99 stuff off the engine and install the 95 stuff.
Old Jul 21, 2013 | 10:46 PM
keilkravec's Avatar
keilkravec
Check the FAQ2 page for the most info, but in short, your going from a OBDII to OBDI computer stuff. all wiring, sensors, etc have to be changed as well as the oil pan and some other odds and ends.
Old Jul 22, 2013 | 08:27 AM
rushings4's Avatar
rushings4
Yes both are V8's.
Old Jul 22, 2013 | 09:58 AM
keilkravec's Avatar
keilkravec
then life is easy. Swap all your 5.2 stuff over to the newer engine. You will need to swap over the throttle body, all the sensors, oil pan and possibly pickup screen, dipstick(most likely) and make sure you have the right pcm, If your going to a 5.9 you will need the right pcm(ram unit works fine) and an intrepid fuel pressure regulator to get 60psi in the fuel system. use your stock exhuast and wire harness and engine mounts.
