1992 dodge Dakota service codes
Old Nov 6, 2014 | 03:20 AM
scrollshawn's Avatar
scrollshawn
Default 1992 dodge Dakota service codes
I figured out the turn the key three times ,How do I read the blinks and where do I get the codes ? The problem I having is the tack omiter is bouncing around , every once in a while it will stall and now it's like its not getting any gas I looked it up I think it's the throttle position sensor . Any other suggestions?
Old Nov 7, 2014 | 12:45 AM
RalphP's Avatar
RalphP
Check the info at http://www.allpar.com/fix/codes.html for starters.
Also, the BEST source would be to grab a copy of the Factory Service Manual from Ebay, but in the meantime, you can always sign up for AllDataDIY .
RwP
