VIN Number decoder/specifications
Old Jan 13, 2015 | 04:12 PM
DAKOTASPORT19954X4's Avatar
DAKOTASPORT19954X4
Default VIN Number decoder/specifications
I was wondering if there is any way that you can find a decoder that tells you all about the specs of your truck i have a 1995 dakota sport 5 speed 5.2 and need to find out front differential ratio and there is no tags on diffs and the hood tag has been ripped off and i was wondering if there was a way you could look up a vin decoder that told you the ratios if anyone can help me find a decoder or wants to compare their vins so i know mine has the same equipment i would greatly appreciate it thanks.
Old Jan 15, 2015 | 08:15 AM
RalphP's Avatar
RalphP
Not directly, no, but if you'll look in the Second Gen Dakota forum, there's a link to get the build sheet. They only go back 25 years, so I'm out of luck on my 1988, but your 1995 is within the range.
RwP
Old Jan 15, 2015 | 11:32 AM
DAKOTASPORT19954X4
Thanks ralphp i just sent a build sheet request to dodge ill see what happens.
