Transmission. Interchangeable? Identification
Old Sep 2, 2017 | 07:15 PM
Jon Johnston's Avatar
Jon Johnston
Default Transmission. Interchangeable? Identification
Having an issue with identification on a tranny that i picked up.
came off a 89 v6.
Want to know if this tranny will work on my 93 V8.
Cant read the paper sticker on it.
there is a number stamped on the driver side above tne pan.
Pk 4531281. 0051. 9456
Number on the back top of tail shaft is
4461106. J. 2
number on bell housing
178-2
Can anyone tell me what trans. I have?
sq. Pan with one cut corner.
will this v6 tranny work in my v8?
Old Sep 7, 2017 | 07:15 AM
robertmee's Avatar
robertmee
came off a 89 v6.
4461106. J. 2
178-2
It's probably an A500/42rh. Your 93 likely has a 518/46rh behind the V8. It'll fit with some hole modifications on the flex plate, and bolt up to your engine, but don't expect it to last too long. I mated an A500 to my magnum 360 pushing 400 HP, but I had it rebuilt with performance clutches/bands and V8 internal hardened parts. Basically a 46rh with the gearing of an A500. The gear ratios are a bit different in the A500...higher lower gear I believe.
Old Sep 14, 2017 | 12:01 AM
Jon Johnston
Thanks for the info. Robertmee.
not wanting to push my luck with a older tranny. Not planing on rebuilding it.
So im looking for a 518 46rh tranny for now.
Plan on building a 5.9. Lt motor in the future and rebuilding the tranny at the same time.
untill then i picked up a 92 sport for $200 (non runner) figured out what was wrong with it. So im driving that around while i save up some parts. Interesting what you did with your tranny. Gearing can make a lot of difference.
