Front Suspension Rebuild
Old Sep 8, 2017 | 08:36 PM
Anderson Knight's Avatar
Anderson Knight
Default Front Suspension Rebuild
Hello Everyone, I am new to this whole forum thing. Thought i would give it a try as I'm doin some DIY suspension work on my 96 Dakota 2WD.
Ok so, Ill start by listing all the parts i know it needs:
- upper and lower control arm bushings
- upper and lower ball joints
- tie rod ends
- sway bar linkages (not sure if thats what you call them)
- struts
Ive got a little bit of experience with minor suspension work on other vehicles. I have watched a bunch of videos online, I've gathered all the necessary tools (i hope), I've got the Haynes manual, and I'm feeling buff. However, i have never used or worked with bushing and ball joint presses. is the lower easier/harder then the upper? Is this something that can be done semi efficiently? or should i save myself the frustration and just replace the whole control arm?
Also where is the best place to get the listed parts?? Online? or can i go to the auto store and get them?
Any ideas, advice, personal experiences, or sources of info is greatly appreciated!
Old Sep 9, 2017 | 10:35 AM
robertmee's Avatar
robertmee
- tie rod ends
- struts
I responded to your other thread
Old Dec 1, 2017 | 08:52 AM
Brian in Tucson's Avatar
Brian in Tucson
Where are you in AZ? Some suggestions, you can borrow the tools at Autozone. They charge you the price of the tool and refund when you bring it back. I'd get the parts at Rock Auto, don't forget the 5% discount. Pretty much the best prices. I have the ball joint press kit from Harbor Freight. Works well. Helps to have access to a vice, a compressor, and an impact driver. I'm in Tucson, you're welcome to borrow mine (or bring you control arms and I'll press them out and in.) Autozone has two sizes of pullers for the tie rod ends. You need the larger one. (I have both.) Your truck doesn't have struts, shocks and springs only. Rockauto is having a close out on KYB, $15 or so. I've been happy with them on my 96 4wd.
Safety. Use jackstands! And safety glasses!
