Not trying to piss anybody off. crank no start, Need help
Old May 2, 2020 | 01:24 AM
Devon Farber's Avatar
Devon Farber
Default Not trying to **** anybody off. crank no start, Need help
I'm still learning how to post threads. I'm obviously having difficulty navigating the site.
swapped ecm, that lasted 3 days. Died on highway.
Steady idle sputter declined till death. New fuel pump stuck on E. I'll cut a hole in the bed rather than drop the tank again to make float adjustment, or pump position rather.
everything else has been replaced or swapped, but for the 2 thermo switches in front manifold.
Correction
Old May 2, 2020 | 01:51 AM
Devon Farber
Correction
fukinchrist. I cant upload more pics...
Yes, battery deleted. Running lifepo4, resting voltage 13.5v
My wife left me cause i work on this bitch too much she said.
Checks out. Side by side with another 92, 318 magnum
The magnum donor(runs)
Stranded on highway, read about coolant temp dash sense, possible backward no start too cold??? Did find and replaced terminal
Stock donor, un molested
Molested, modified made mo betta
Alt b+ and ground distro
Raw unsheathed bundle behind and above y pipe got cooked, feels like clumped spaghetti noodles. Couldnt reach to thoroughly inspect, which i suspect could be causing this.
