Transmission Position Sensor
Old Jun 2, 2020 | 12:48 PM
Jeff52's Avatar
Jeff52
Default Transmission Position Sensor
I have a 1993 Dakota 5.2 two wheel drive and it is having trouble starting without jimmying around the shifter to try to get it in park anyone have any ideas how to fix this? I already adjusted the linkage where it enters the tranny
Thank You
Jeff
Old Jun 2, 2020 | 06:11 PM
RalphP's Avatar
RalphP
What kind of shape are the bushings for the shift linkage?
Some are still available as Mopar parts; some can be used from Dorman; you can rebuild and replace all the nylon (or "plastic") bushings in the system.
RwP
Old Jun 2, 2020 | 08:43 PM
Jeff52's Avatar
Jeff52
Thank You
Old Jun 3, 2020 | 08:24 AM
Neutral safety switch may be failing as well.
