95' Dakota Questions
Old Apr 25, 2007 | 11:26 PM
OldDakota's Avatar
OldDakota
Default 95' Dakota Questions
I have a few minor problems with my recently purchased 95 Dakota SLT 3.9L Auto 4X4. First is that the heat/ac blower is always on. No matter what position the swich is in, it's always blowing on high. I've checked under the hood and found the resistor block which looks like it's already been changed. (I think it's been changed because there is no longer a plug end on the wires they're just individually hooked on to the block prongs.) Could this be aproblem with the switch or could it be that the wires arescrewed up on the resistor block?
Alsothe check engine light comes on after I drive thetruck alittledown the road. I plugged in my scanner and it comes up with a code saying something like "EGR Solinoid CircuitMalfunction"(Code 32) I assume it's maybe a bad wire or something to the solinoid butwhereis the EGRsolinoid? Any Help???
Thanks
OldDakota
Old Apr 26, 2007 | 12:21 AM
peckens's Avatar
peckens
Default RE: 95' Dakota Questions
if you take your dash cover off you can pretty much see right into the AC switch, im assuming something snapped
