95 Dakota wants to stall on takeoff
Old Jun 3, 2007 | 06:49 PM
Dav2236's Avatar
Dav2236
Default 95 Dakota wants to stall on takeoff
I just bought a 95 3.9 and it idles fine, runs at speed fine but when I hit theaccelerator it wants to die. Any help would be appreciated.
Old Jun 8, 2007 | 09:50 PM
biggin42003's Avatar
biggin42003
Default RE: 95 Dakota wants to stall on takeoff
R134A
Old Jun 9, 2007 | 04:12 PM
belowrdr's Avatar
belowrdr
Shakey idle/hesitation-stumble on throttle tip-in? Sounds like the oil pump drive/distributor bushing could be worn. Look close at the gear & part of the shaft that mates to the bushing, while it's out- the earlier Magnum 3.9's had wear problems on those (theMopar replacement gears are hardened to prevent reoccurance), & would sometimes wear bad due to the bushing .
