tranny bands?
Old Jun 21, 2007 | 11:11 PM
projectdakota22's Avatar
projectdakota22
Default tranny bands?
Hey, I was wondering if there was a special tool needed to fit over the the tranny adjuster bolts?A regular wrench would work but that won't allow me to torque the screws properly... Any ideas? its a1994dak with a46Rh
Old Jun 23, 2007 | 01:18 AM
kahanabob's Avatar
kahanabob
Default RE: tranny bands?
On my 90 adjusting the bands is done by tightening them all the way and backing of a certin # of turns, no torqueing is required. Maybe differant on a 94?
Old Jun 30, 2007 | 12:29 AM
grcforce327's Avatar
grcforce327
5/16 wrench for the adjusting screw and 3/4 wrench for the set nut.All are the same.I adjust by travel and not screw turns. 1/8 in lever travel by hand for the 2nd band(flex style band),and 1/4 lever travel for reverse band.Factory setting are always to loose.Once adjusted,tighten band nut with wrench(tight) while keeping screw stationary.
Old Jun 30, 2007 | 12:59 AM
dodgerules86's Avatar
dodgerules86
You may need special tool C-3705, made by SPX Miller.
Looks like it could be easily made by yourself.
[IMG]local://upfiles/948/7C64D107C8D4404AA0D7071412049848.jpg[/IMG]
Old Jul 1, 2007 | 12:29 PM
grcforce327
ORIGINAL: dodgerules86
Save your money!I've done a few 100 trannies and don't have one.
Old Mar 18, 2008 | 10:42 PM
dakotapappy's Avatar
dakotapappy
thanks for the heads up on this toppic i'm going to tighten the bands on my 89' LE was not quite sure about the whole thing but now i beleive i can do it thanks again
