Tach. off
Old Jun 29, 2007 | 02:38 AM
Bad96_3.9's Avatar
Bad96_3.9
Default Tach. off
Is it common onthe dakotas for the tach. to be off. Mine says that it is idling at 100-200 rpms and i know its not, it also bounces off 5,000 on the revlimiter, so i just wanted to see if mabey i was turning out even more than that. If anybody has fixed this can u let me know. Is the revlimiter 5000?
Old Jun 29, 2007 | 03:44 AM
dodgerules86's Avatar
dodgerules86
Default RE: Tach. off
My tach reads (probably) accurate, usually idles around500-900RPM depending on all the factors that effect it.
I've never *intentionally* gotten it really close to 4,800RPM (redline) to see if it limits the RPM (I've gotten the needle close quite a few times, but back off the throttle).
There should be a way to get accurate RPM readings to see how accurate the tachometer is (btw, evidently controlled by some module stashed above the cluster).
Old Jun 29, 2007 | 02:42 PM
Bad96_3.9's Avatar
Bad96_3.9
Mine always sees the limiter
Old Jun 29, 2007 | 09:33 PM
jonnymagnum's Avatar
jonnymagnum
mine seen the limiter for a week straight every time I shifted. but the motor would never blow, those damn 3.9's go forever
Old Jun 30, 2007 | 12:19 AM
dodgerules86
Yea... and since I don't like the idea of taking out a perfectly good motor (and I, for the most part, take pretty good care of my truck), I probably won't be swapping in some V-8 any time soon.
However, I saw a '07 Ram 2500 4x4 Cummins in Infernored([sm=Awwww.gif]) yesterday... if I made about $550 a month more, I'd of bought that, and my Dakota would be seeing a new engine.
Old Jul 2, 2007 | 05:15 PM
Bad96_3.9's Avatar
Bad96_3.9
yea, i have got mad at mine a few times and tried to blow it up and it never will.
