Another dieing Dakota question.
Old Jun 21, 2008 | 12:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Another dieing Dakota question.
The board inside the pcm is bad.
Old Jun 21, 2008 | 12:59 PM
thegreatpumpkin's Avatar
thegreatpumpkin
Ouch !!! Fix-it guys said they would find me a "good" one from the junk yard.
Guess i'll have to go that route . Thanks !!!
Old Jun 21, 2008 | 01:05 PM
zman17's Avatar
zman17
You can try cleaning the plugs and checking the wires going into the pcm, but this usually doesnt work,
Old Jun 21, 2008 | 11:40 PM
jlbritt1's Avatar
jlbritt1
As far as the not starting issue, I can't help any more than what has been stated. The dying portion, on the other hand, is a different story. Had the same problem with a '98 Cavalier, tried to die when coming to a stop, etc... Turned out to be a cat problem. Changed that, and the dying went away. Changing, o2 sensors, and throttle/carb cleaner helped for short durations, but not long. Worth a look.
Old Jun 22, 2008 | 11:04 AM
thegreatpumpkin
Thanks !!!
Old Jun 25, 2008 | 08:57 AM
thegreatpumpkin
Well, Sunday the 22nd I took the plug-in to the computer off. There was a small amount of corrosion on about 6 different pins. I used a clean (new) paint brush and brushed the heck out of the "male" pins and cleaned the green powder out & off the "female" side with a utility knife. Re-brushed both and put back together. Haven't had a problem YET. I'll consider it fixed after 3 weeks of no problems. That's if I can afford the gas in that big V-8
