HAULING WEIGHT WITH 1ST GEN.
Old Jul 13, 2007 | 12:39 AM
winter ride's Avatar
winter ride
Default HAULING WEIGHT WITH 1ST GEN.
i need to pick up a few loads of rock with my 92 dakota ? ..is how much weight can i haul safely?,
if it maters it's a club cab with the 318 & tow package.
thanks
Old Jul 13, 2007 | 11:23 AM
MacDak's Avatar
MacDak
Default RE: HAULING WEIGHT WITH 1ST GEN.
If you mean in the bed, I wouldn't go over what's recommended in the manual. For towing, my '93 3.9 L. V6 is rated to tow 5,200 lbs., and I tow a 4,500 lb. travel trailer with no problems.
Just be careful not to overload, and make sure you have good brakes!
Old Jul 13, 2007 | 11:40 AM
Bad96_3.9's Avatar
Bad96_3.9
I have pulled our 23' proline witha cuddy cabin behind mine, it pulled it pretty goos, but stopping was kind of scary, have not tried it again.lol.
Old Jul 14, 2007 | 12:51 AM
winter ride
yes in the bed of the truck, thanks for the replys.made 2 trips first load was 1780lbs drove nice, 2nd load was2440 lbs.could tell i was loaded that time and stopped alittle slower. the last loads i'll try keeping around 2000lbs... thanks again
Old Oct 7, 2007 | 11:15 AM
BurlesonDakota's Avatar
BurlesonDakota
My old dakota would pull and haul with any full sized pickup but stopping was always an adventure. they really should have put bigger brakes on them.
Old Oct 7, 2007 | 09:39 PM
hemichuck's Avatar
hemichuck
I had a 1992 club cab and I towed quite a bit with it.stopping was an adventure with the original brakes.My remedy was to take the front hubs from an 89 dakota and put them on the front(for the 5 lug wheels) and then I switched the rear axles to the 5 lug axle and added a set of 11 by 3 backing plates and drums off of an old Roadrunner I had laying around.Not only got a greater selection of cheap wheels to buy but had much better rear braking capacity and retained the anti lock feature.Any hubs and drums off of an 8 3/4 or the 8 1/4 rear ends will fit on a Dakota.Every old C-body in the junkyards had at least 11 by 2 1/2 drums.Good cheap trick for brakes.
Old Oct 8, 2007 | 09:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I have hulled a nice fat trailer that weighed about 5,000. And loaded the bed with 3,000lbs. Hell of of lot of concrete. Ialso have loaded up 1,700 of tile.That is highest twoI have done.I havea ram 2500 rear springs Along with air shocks (added in before the springs)but I have never use them I dont put much psi in them. and trany and all is strong enough for it. Ya the brakes suck but I have the best pads and drilled and slotted rotors. Still can be scarry. But just go slow and use the engine brake if you need too.
Old Oct 14, 2007 | 04:26 AM
the pumkin driver's Avatar
the pumkin driver
I had 2000lbs of brick and plaster in my '94. stopped ok but the front suspension bolt broke when I came off the sidewalk
Old Oct 14, 2007 | 12:49 PM
fox's Avatar
fox
I hauled about a 4000lb massey ferguson tractor defentinly could feel the load on the brakes but I have trailer brake module intalled in my truck so the helps a lot too.
Old Oct 14, 2007 | 12:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I only have a pic. of my trailer I go up in the moutains in. and My 82 TA dragster. That is when I first bought it and a pic of how it is now.
