check light
Old Jul 22, 2007 | 01:11 AM
cheesebagel's Avatar
cheesebagel
Default check light
how do i get my Abs check light to go away and how do i get my Parking Brake light to go away????much help needed
Its a 93' 3.9 v6
Old Jul 22, 2007 | 02:14 PM
cheesebagel
Default RE: check light
mycodesare 12 and 55. please help
Old Jul 22, 2007 | 03:27 PM
cheesebagel
ok. was reading and 12 and 55 are normal. so does anyone now how i can get the Abs and Parking brake light to go away?
i have to disconnect my battery everytime i turn off my truck or i will go dead in about 20 mins.
Old Jul 22, 2007 | 07:15 PM
dodgerules86's Avatar
dodgerules86
Common cause of the parking brake and ABS light to stay on (when the parking brake is not set, of course ) is failure of the rear wheel speed sensor. This is located on the top of the rear differential.
Old Jul 23, 2007 | 10:10 PM
Nicegy525's Avatar
Nicegy525
thought I would add my problem to this thread. My ABS is showing code 4 "closed HCU RWAL reset switch" I performed the HCU test as described by the Mitchell book and came up with nothing. The HCU connector looks good and the 14 pin ABS connector looks good.
