disc brake sticks
Old Jul 24, 2007 | 10:35 AM
atc250r's Avatar
atc250r
Default disc brake sticks
1990 dakota 2wd has a right front brake that intermittently sticks on. I assume the piston is not sliding as smooth as it should. Is the rubber seal around the piston removable in order to clean and lube the piston? Any other causes or easy fixes I am missing? Thanx.
Old Jul 24, 2007 | 11:19 AM
fishlessman's Avatar
fishlessman
Default RE: disc brake sticks
dont mess with rebuilding it if its the caliper, the whole caliper is about 30 dollars, its cheap and brakes are important. it could be the shoe, the clips on my 89 are odd and a pain to put on and get them to slide properly, it took a little grinding to get the aftermarket shoe to work properly
Old Jul 24, 2007 | 01:31 PM
kahanabob's Avatar
kahanabob
Ditto Fishlessman, same thing with my 90 last year. I thought I would save and did the rebuilding kit worked for about a month. I ended up replacing both calipers. Mine came with new pads.
Old Jul 24, 2007 | 02:31 PM
atc250r's Avatar
atc250r
Guess I'll replace the caliper. If the rotor needs to be machined/replaced, is it OK to just do the one that got hot? The left one is fine. Thanx for the knowledge.
Old Jul 25, 2007 | 01:22 PM
kahanabob's Avatar
kahanabob
My right one went first 6 mos later the left. I did them 1 at a time but if I were to do it again I would just do both and be done with it.
Old Jul 26, 2007 | 04:29 PM
atc250r's Avatar
atc250r
I'll take your advice. Thanks guys.
