Used or Aftermarket Pulleys?
Old Jul 31, 2007 | 07:53 PM
Nicegy525's Avatar
Nicegy525
Default Used or Aftermarket Pulleys?
Anyone know where I could find a used or aftermarket pulley for the 3.9L V6 on a 1990 Dak? The dealer wants $160 bucks for the two I need. Looking for a less expensive option.
Looking for the crankshaft pulley and the water pump pulley. I thought there might be a website somewhere. Thanks!
Old Aug 2, 2007 | 12:35 AM
peckens's Avatar
peckens
Default RE: Used or Aftermarket Pulleys?
have you gone to a local parts store or a junk yard?
Old Aug 2, 2007 | 12:41 AM
Durango911's Avatar
Durango911
If the pulleys off my 1999 5.2 will work, you can pretty much have them. I would look for some aftermarket ones,maybe jet performance has some.
Old Aug 2, 2007 | 03:53 AM
DirtyBeds's Avatar
DirtyBeds
Yea not to mention you can usually get underdrive pulleys for less than the dealership will charge for OE specs.
Old Aug 2, 2007 | 01:15 PM
Nicegy525's Avatar
Nicegy525
None of the local parts stores or junk yards even keeps pulleys. I think I may just live with the wobble and the slight rattle. But thanks for the input.
Old Aug 2, 2007 | 01:34 PM
fishlessman's Avatar
fishlessman
i paid somewhere near 50 dolars for a small simple idler pulley from the dealer last year, none at the 3 parts stores had it or could get it. the dealer was highway robbery for that part. i needed it right away and didnt have time to look for something similar in a junkyard.
Old Aug 2, 2007 | 04:24 PM
DirtyBeds's Avatar
DirtyBeds
that's strange where you guys at because autozone can get all the pulleys i want. Also try summit, jegs, jcwhitney, dodgeparts.com, moparperformance.com, even Ebay! lol
Old Aug 3, 2007 | 01:35 PM
fishlessman
i get most everything from napa and autozone, i tried a third, autopalace and they all said the same thing, go to the dealer. if i didnt need it right away i would have just found any similar pulley and got it on there. its the first time i had a problem getting a part except for the convertible roof, those parts arent anywhere and i would like some new gaskets for it before the where out, also the stripe kits seem to be all gone for the 89. ive also had good luck with worldpartsexpress.com
