94 Dodge Dakota
Old Aug 10, 2007 | 02:23 PM
Txn_b0i's Avatar
Txn_b0i
Default 94 Dodge Dakota
I have a 1994 Dodge Dakota V8 5.2L/ Manual.
I was wondering what all I could do to customize it. Speed, looks, everything.
If anyone knows a good site for older Dakota parts or has suggestions please let me know.
Also, it'd be cool if you gave me ideas on how to customize it.
Thanks a lot.
Old Aug 14, 2007 | 12:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: 94 Dodge Dakota
Try jegs.com jcw.com summitracing.com andysautosport.com there is alot you can do. from steping up the motor with a larger throttle body to changing fuel injecters. you can add a brush grill or body lift or lower gear raios for your rear end. its all up to your imagination. if you cant afford alot of stuff go to junkyards or check the newspaper or swap meets. keep in mind of buying other parts from trucks you can make work. drill extra holes and add a brace here and there just do your homework and take your time.
Old Aug 14, 2007 | 08:20 PM
Jasonx's Avatar
Jasonx
good advise i mean these older truck are a very sturdy platform and built right will do just about anything you can imagine
