Brake Light/ Signal light question
Old Aug 21, 2007 | 04:08 AM
RJTDakotaBoy's Avatar
RJTDakotaBoy
Default Brake Light/ Signal light question
So my brake lights and signal lights do not work on the 87 Dakota I am restoring. I have checked the bulbs and the wiring in the rear and everything is good so I am thinking go along the frame and check the wiring. If that checks out then I am thinking it's the singnal light clicker or the fuses. Any other ideas? Thanks
Old Aug 21, 2007 | 04:39 AM
dodgerules86's Avatar
dodgerules86
Default RE: Brake Light/ Signal light question
Yea, I'd check all the wiring, but it could end up being the turn signal switch, but obviously, don't go running to replace this.
You might try using a wiring diagram and jumper wires at the electrial connector for the turn signal switch.
Go to the 1st Gen FAQs page and look about half-way down the page. I know there are differances between 1987 and 1990, but some of the chassis wiring might be the same,I don't know.
Old Aug 21, 2007 | 09:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Check the fuses first! Then check at the light. to see your geting power. The best was is with a multimeter.Check the diagram that dodgerules86said.See if you have ground or power. If you dont have ground then make a jumper wire to put ground on that wire to see if it works. If you dont have power check the fues to see if it has power. If not put power on it see if it works then. If nothing then check the switch. Good luck.
Old Aug 22, 2007 | 03:19 PM
RJTDakotaBoy
Alrighty Thanks. I would go get on it but it looks liek it's gonna rain and it's cold and I'm not working in a garage
