trans.line help please
Old Aug 28, 2007 | 09:31 PM
Jasonx's Avatar
Jasonx
Default trans.line help please
hi guys just replaced my water pump and went to put everything back together again and found i was leaking trans. fluid from the rad. i had just put back it . . got to looking at it the little o ring in the i guess its a quick connect, the o ring is busted where do i find a new one please otherwise im stuck or any alt. to fixing the prob would help to thanks alot
Old Aug 28, 2007 | 09:53 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: trans.line help please
Ya if the hose is ruber and its long enough just cut it and put it on the raid. connector and use a hose clamp. if it dont reach buy a new line from autozone or somewhere. make sure its aproved for tranny oil. the temps are hot and oil will leak through cheep hoses.
Old Aug 28, 2007 | 10:11 PM
Jasonx's Avatar
Jasonx
yea no way it would reach how much would another tranny line run . . .and how do you cut the metal line wihout bending it lol
Old Aug 28, 2007 | 10:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
They charge per foot. I think around $3 per foot. Use a pipe cuter. Thekind that you turn around the pipe and tighten as you turn. If you dont have one most auto stores will have it for $5-10. Make sure its small enough for your line. When you use it, it might leave some burs on it, clean it up the best you can.
Old Aug 28, 2007 | 10:46 PM
Jasonx's Avatar
Jasonx
thanks alot will do it tomarrow morn and be back on da road thanks loads
