black smoke
Old Sep 19, 2007 | 06:46 PM
nvrhapy's Avatar
nvrhapy
Default black smoke
hey guys im new and got some questions, i just bought a 92 dakota 2wd with a 318 in it it has 170,000 miles on it and black smoke comes from the exhuast what could cause this besides the o2 sensors i already replaced the plugs, cap, rotor and wires what else should i do? thanks
Old Sep 19, 2007 | 09:03 PM
Nicegy525's Avatar
Nicegy525
Default RE: black smoke
a new motor. : )
Old Sep 19, 2007 | 10:23 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Black smoke meens its running rich. You could check your fuel system maybe a fuel injector isnot working correctly or bad fuel pressur regulator. or dirty fuel.
Old Sep 19, 2007 | 10:25 PM
f0x672's Avatar
f0x672
just happened to notice the title but, maybe its a diesel and you dont know about it , haha just kidding, yeah i wouldnt put it past me your running extremely rich, notice your fuel gauge drop faster then normal?
Old Sep 19, 2007 | 11:01 PM
fox's Avatar
fox
heh or ur burnin oil like i was took off my heads all my pistons were black with burnt oil[sm=yikesomg.gif]
Old Sep 20, 2007 | 08:30 PM
nvrhapy's Avatar
nvrhapy
yea not sure what it could be hopefully just running rich because of a sensor or something thats what im hoping i dont know if its burning gas more than usual i dont drive it i tore it all apart and starting to fix it up custom interior, paint and an air suspension. if i do a compression test that will tell me if its burning oil real bad right. or is there another way it smells like gas though from the exhuast which led me to believe its running rich???
Old Sep 20, 2007 | 08:34 PM
Nicegy525's Avatar
Nicegy525
have your used oil analyzed for blow-by. not sure where you can take it to have that done but that will tell you if you have internal problems or not.
Old Sep 20, 2007 | 08:39 PM
nvrhapy's Avatar
nvrhapy
wow nvr heard of that not sure about any one that does it either
Old Sep 21, 2007 | 02:24 PM
fox's Avatar
fox
A compression test will not tell you the condition of your rings for that you have to do a wet compression test.
