1987 Dakota Transmision Help
Old Oct 3, 2007 | 10:42 PM
wildfan1833's Avatar
wildfan1833
Default 1987 Dakota Transmision Help
I have a 1987 Dakota and I want to replace my transmision, I was wondering if the 904transmision is the sameon a V8 as it is on a my V6? Let me know.
Old Oct 4, 2007 | 05:45 PM
hemichuck's Avatar
hemichuck
Default RE: 1987 Dakota Transmision Help
You can use any 904 \999 off of a small block with the only difference being that yours is probably a lock up converter.You just want to use the converter that comes with the transmission that your installing.Make sure the converter doesnt have any offset weights like a 360 would have(if it does just grind them off)Good luck
